Date/Time: Fri, 03 May 2024 04:16:12 +0000
LMAX Live data feed
View Count: 759
[2021-07-27 11:45:34] |
User149854 - Posts: 1 |
Hi, Is the data feed on the LMAXDemoTrading.DTC trading service using the LMAX demo data feed or the Live Data feed? (I understand that the demo data feed samples the live feed at a rate of X seconds). If it is the demo data feed is it possible to get the Live LMAX data feed on Sierra Charts without having a broker account? The reason i ask is beacause i am going to trade spot forex for a prop firm that has LMAX but only has MT4 and Ctrader charting packages. I like Sierra charts much better so i want to use Sierra charts for analysis but will have to execute trades using the propfirm's platform/charting packages. If the above is possible which Sierra Chart which package do i select to purchase? Kind regards |
[2021-07-28 14:54:10] |
This is the LMAX demo data feed. If it is the demo data feed is it possible to get the Live LMAX data feed on Sierra Charts without having a broker account?
No we do not think so.However, if you already have access to an LMAX account, if you follow the instructions here we can set up access to it so you have access to the real-time data feed: LMAX Trading Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
