Date/Time: Fri, 03 May 2024 13:07:33 +0000
DOM profit showing only in ticks
View Count: 589
[2021-07-27 04:29:26] |
User425645 - Posts: 113 |
my DOM profit is showing only in ticks. My chart settings are set to $ - what am i doing wrong? thank you.
Capture.PNG / V - Attached On 2021-07-27 04:28:17 UTC - Size: 42.88 KB - 187 views |
[2021-07-27 13:54:44] |
John - SC Support - Posts: 31334 |
You need to left-click at the top of the P&L column to change the format. Refer to the following: Chart Trading and the Chart DOM: Chart DOM Position Profit and Loss Column For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-27 19:24:02
[2021-07-27 18:40:12] |
Refer to: Profit/Loss Calculations and Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-27 18:42:45
