Date/Time: Thu, 02 May 2024 09:34:46 +0000
Triggered Limit Orders
View Count: 391
[2021-07-26 18:51:35] |
User187934 - Posts: 40 |
When using triggered limit orders I understand that these orders are held client side until triggered. However once triggered does my bracket get sent through to the server in the same way that my current limit and attached bracket is server-side? I am using the TT Fix. Also is it possible to add the triggered limit order type to the chart DOM? |
[2021-07-26 22:55:26] |
Sierra_Chart Engineering - Posts: 14173 |
Is this Triggered Limit order an Attached Order?
[2021-07-27 06:16:21] |
No I am using the triggered order to open the position and then the attached bracket consists of a limit order take profit and a stop order stop loss
[2021-07-27 09:05:34] |
However once triggered does my bracket get sent through to the server in the same way that my current limit and attached bracket is server-side? Yes.Also is it possible to add the triggered limit order type to the chart DOM?
We would have to see about this, but do not expect this to be added.
[2021-07-27 09:09:16] |
Thanks for clarifying. Great support!
