Date/Time: Sun, 05 May 2024 14:46:47 +0000
Copy control bar from one instance to another
View Count: 806
[2021-07-26 15:09:27] |
countryboy92 - Posts: 90 |
I have customized a control bar in Global Settings. How do I copy this control bar to a new window?
[2021-07-26 18:05:46] |
John - SC Support - Posts: 31362 |
To get the Control Bar onto another window within the same instance of Sierra Chart, just go to Window >> Control Bars and select the control bar you want to add. Refer to the following: Window and CW Menus: Control Bars >> Control Bar [1-8] (Window) If you are asking about how to get that configuration to a different installation of Sierra Chart, then you would need to copy the Sierra4.config file from the one install to the other. For more information on the files and how to copy them, refer to the following: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
