Date/Time: Wed, 08 May 2024 20:55:22 +0000
S_ID meaning in Studies window
View Count: 623
[2021-07-24 14:59:01] |
PS2004 - Posts: 37 |
Hi, I recently came across a new tag for the Studies listed in the Studies window. Now the template of each Study's decription for example looks like this: 1 (Number) | ID: 1 (Study ID) RSI (Study Name) | CalcOrder: 1 | S_ID: 38 Could you tell me what is "S_ID" means, and do I have to deal with it during writing Custom Studies in ACSIL? |
[2021-07-24 22:49:40] |
Every study has its own fixed integer identifier and this is what that value is.
[2021-07-24 22:53:44] |
So I don’t have to do anything about it in ACSIL? And can two Study have the same identifier? |
[2021-07-28 01:40:57] |
The identifier would only be used with this function: sc.AddStudyToChart() Yes multiple studies can have the same identifier, if they are implemented as custom studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-28 01:41:19
