Date/Time: Sat, 04 May 2024 17:54:11 +0000
duplicate chart to chartbook
View Count: 1105
[2021-07-24 11:40:09] |
Bankson H - Posts: 15 |
Dear Mr/Mrs, I want to duplicate a chart from one chartbook to another chartbook. When I use the “duplicate chart to chartbook” function, I can’t see all the chartbooks, where I want to duplicate the chart to. How can I solve this? Regards Date Time Of Last Edit: 2021-07-24 11:50:29
[2021-07-24 13:27:08] |
Sawtooth - Posts: 3993 |
The chartbook you want to duplicate to must be opened. Only the open chartbooks will be in the list. |
[2021-07-26 03:57:20] |
Yes you do need to have the Chartbooks open that you want to have listed. Refer to: Chart Menu: Duplicate Chart To Chartbook (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-26 07:25:31] |
User90125 - Posts: 715 |
Would be nice to have a {New Chartbook} listed as a selection when duplicating. Of course, by default, the {New Chartbook} should open with the duplicated chart active in it. Possible? |
