Date/Time: Mon, 29 Apr 2024 06:17:22 +0000
Running Clock that starts from a trigger and resets with another trigger [SPREADSHEET]
View Count: 342
[2021-07-23 15:18:55] |
User355030 - Posts: 163 |
Is there a way within the spreadsheets to have a running clock start when a trigger is met and then to reset the clock when another trigger fires off? @SCE @TOMGILB |
[2021-07-23 16:04:18] |
Sawtooth - Posts: 3982 |
Here is an example that you'd need to modify: Spreadsheet Example Formulas and Usage: Cancel Unfilled Working Order n Minutes After Entry Spreadsheet Example Formulas and Usage: Cancel an Unfilled Order After n Bars You'll need to create a persistent value of the time at the first trigger, then reset it at the second trigger. You can only use FRACTIME(A3) because it's not possible with a spreadsheet study to capture an intrabar time from J41. You would then compare the persistent FRACTIME at the first trigger with the current FRACTIME of J41. |
