Date/Time: Mon, 29 Apr 2024 02:36:00 +0000
Different levels for the same tool
View Count: 378
[2021-07-22 16:09:46] |
User140175 - Posts: 3 |
Together with a few friends, we use VWAP and standard deviations. The problem is that on some graph we have +1 standard deviation at a different level. Do you know what can cause the problem? We use the same template, the same broker. Thank you! |
[2021-07-26 03:25:55] |
First review the information here about this: Volume Weighted Average Price (VWAP) with Standard Deviation Lines: Differences Between VWAP and Standard Deviation Lines On Different Timeframe Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
