Date/Time: Fri, 26 Apr 2024 11:05:43 +0000
Adding Indicator To Main Chart Not SubGraph
View Count: 426
[2021-07-22 02:59:21] |
User123194 - Posts: 1 |
Hi I am new to ASCIL coding and am just using the basic example for indicator creation in the documentation. When adding the indicator to the chart it adds a new window below price instead of overlaying on the same chart as price. I will need to be able to add indicators to the main graph for my future projects so I was wondering how I go about doing that in the code.
[2021-07-23 05:10:34] |
This is controlled by the Graph Region variable: ACSIL Interface Members - Variables and Arrays: sc.GraphRegion Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
