Date/Time: Thu, 02 May 2024 22:53:56 +0000
Micro CL Futures
View Count: 538
[2021-07-20 15:42:44] |
User525384 - Posts: 37 |
Cannot find the Micro CL, has it been added yet?
[2021-07-20 16:31:54] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-07-20 19:39:25] |
Trying to place some limit orders far from the market for MCL and I am getting the following message: SC/TT Futures Order Routing update(order reject). info: TT order update (Rejected). Text: No Limits, etc. I can attach a screenshot if required. |
[2021-07-21 06:05:36] |
Contact your broker and have them set limits for MCL for your account.
[2021-07-21 11:22:12] |
That's already done.Still having the same issue after I restarted SC and my PC.
[2021-07-22 08:55:59] |
If you are specifically seeing this rejection text: Text: No Limits
Then this comes from the TT system and your broker would need to contact TT for further help. It will not help to restart Sierra Chart or restarting your computer or anything like that. All of that is unrelated. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
