Date/Time: Mon, 06 May 2024 11:49:13 +0000
données
View Count: 438
[2021-07-20 09:53:58] |
Ludovic da costa - Posts: 9 |
bonjour pourquoi depuis cette nuit je n est plus acces au mini dax depuis le 3 juin tout foncionne et cette nuit sa coupé pourquoi |
Capture d’écran 2021-07-20 115238.png / V - Attached On 2021-07-20 09:53:05 UTC - Size: 9.34 KB - 156 views |
[2021-07-20 16:53:20] |
First thing is to update Sierra Chart to the current version. Instructions: Software Download: Fast Update Refer to: July 1, 2021: EUREX Realtime Data from Denali Exchange Data Feed Policy Change your Service Package to 11: To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation You will need to login if you are not currently logged in. In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button. The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price. There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
