Date/Time: Sun, 28 Apr 2024 20:38:10 +0000
Live Streaming...
View Count: 677
[2021-07-20 08:54:43] |
User547240 - Posts: 1 |
Hi there, I am turning to you again, as I am facing a strange issue that I've never experienced before. When I open a a Charbook, my Chart Windows are totally offscreen on my Monitots, I just cannot replace those charts at the right place to fit my Monitors as my initial setup. I am joing a Jpeg ...101 Thanks for your help. Cheers... |
[2021-07-23 07:49:39] |
Are these charts which are offscreen detached charts?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-23 07:49:59
