Date/Time: Sun, 05 May 2024 18:15:57 +0000
Market Depth
View Count: 416
[2021-07-19 23:35:52] |
User575399 - Posts: 305 |
Im using a 5 tick renko chart and I want to implement Market Deptch on the same chart. I only want orders of 100 bid/ask or more to show a color bar, everything else is invisible on the chart. is this possible? Ive messed with all the settings and either the bar will not show up as a color or there is too many making the renko bars hard to read. please help. thanks!
[2021-07-20 06:37:08] |
Sierra_Chart Engineering - Posts: 14234 |
Are you referring to using the Numbers Bars study? Or what.
[2021-07-20 15:10:37] |
No im talking about only seeing orders of 100 or more on MARKET DEPTH. I tried adjusting all the settings .
[2021-07-26 14:48:26] |
John - SC Support - Posts: 31379 |
Set the Value Type for Lowest Quantity for Coloring to Actual Value and then enter 100 in the Lowest Quantity for Coloring. Refer to the information starting here: Market Depth Historical Graph: Value Type for Lowest Quantity For Coloring For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
