Date/Time: Mon, 06 May 2024 08:41:07 +0000
DTC Instance - Orderbook Data Replay Data and MBO Data
View Count: 429
[2021-07-18 14:02:16] |
User230940 - Posts: 121 |
Hello, i am using SC in DTC Instance mode on different screens. 1. Orderbook Data Replay I detect in Replay Mode that the Orderbook data will not be displayed. On the main Instance the Orderbook Data is visible. Is this correct that Orderbook Data is not available on Instances? Is there an plan to provide the Replay Data on Instances too? 2. MBO Data on Instance The MBO Data is not available on DTC Instances too? thanks best regards Is there a plan, to provide the MBO Data on DTC Instances too? |
[2021-07-26 13:53:07] |
John - SC Support - Posts: 31379 |
1. The standard Market Depth is available during a replay in a sub-instance. If it is not working, then you need to look through the issues related to why you may not be storing the Market Depth Data. Refer to the following: Replaying Charts: Replaying of Market Depth Data 2. The MBO data is not available in a Sub-Instance at this time. This is something we will get to, but we do not have a time frame for when. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
