Date/Time: Mon, 30 Jun 2025 20:41:15 +0000
Order Quantity Buttons gives wrong quantity!
View Count: 746
[2021-07-18 13:07:45]
TraderRhino - Posts: 3
Hello folks,
My order quantity buttons appear to give the wrong contract size.
When I press the number 1 on my keyboard, it changes the order size to 100, rather than 1.
When I press the number 2 on my keyboard, it changes the order size to 200, rather than 2.
And so on.
Please advise?
Thanks!
[2021-07-18 15:58:51]
58LesPaul - Posts: 429
Open your trade window and select SET and see if they are set to 100, 200 etc. If that isn't it then IDK.
[2021-07-18 22:38:23]
Refer to:
Basic Trading and the Trade Window: Trade Window Settings Not Applying to Chart or Trading DOM
Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program.
Date Time Of Last Edit: 2021-07-18 22:38:41
[2021-07-22 12:52:17]
User190406 - Posts: 1
Sorry I've look at your suggestion but the order quantity still gets set to the hundreds when I press the corrosponding hot keys
Changing the order quantity manually isn't ideal for quick low time frame entries
[2021-07-22 16:51:37]
Go to the Chart or Trading DOM you are trading from, and select Trade >> Attach Trade Window to Chart.
Provide an image of the chart or Trade DOM, by following these instructions:
Use Upload Chart with Overlays.
You also say this:
This does not make sense to us. Where exactly in Sierra Chart are you entering the 1?
Date Time Of Last Edit: 2021-07-22 16:55:36
