Date/Time: Mon, 06 May 2024 19:41:02 +0000
Studies not linking when changes made via ACSIL
View Count: 406
[2021-07-18 01:17:14] |
User353585 - Posts: 66 |
Hi, when I changed study parameters with ACSIL, the change does not propagate to other linked charts. The linking only happens when I manually click "Apply" button in Studies window. I tried sc.RecalculateChart and sc.FlagFullRecalculate but they won't help either. Is there any way to trigger chart linking using only ACSIL? Please help, thanks. |
[2021-07-19 09:08:21] |
No, this is not supported through ACSIL.
[2021-07-19 10:10:38] |
Can you add one in future?
