Date/Time: Sat, 04 May 2024 00:29:16 +0000
Custom Study CPU Exception
View Count: 863
[2021-07-17 15:44:49] |
Mattc55 - Posts: 97 |
Hello, I am trialing out a custom study from spot gamma (https://spotgamma.com/) and got these error messages about SC potentially becoming unstable as a result. Is that just a generic message whenever one adds an external custom indicator? Are there any actual issues reported with this add-on that you all know of? thx, Matt Triggering next historical data download in queue. | 2021-07-17 11:13:26.183 No download requests in the queue to start downloads for. | 2021-07-17 11:13:26.183 Socket (3) | Socket gracefully closed by remote side. | 2021-07-17 11:13:26.238 Socket (3) | Closed. | 2021-07-17 11:13:26.238 ESU21_FUT_CME [CBV][M] #5 | StartDateTimeForLoadingOrderFills: 2021-05-17 18:00:00 | 2021-07-17 11:13:27.836 ESU21_FUT_CME [CBV][M] 3000 Volume #3 | Performing a full recalculation because it has been tagged. Chartbook: ES_5.Cht | 2021-07-17 11:14:13.948 ESU21_FUT_CME [CV][M] 15 Min #24 | Reloading chart. | 2021-07-17 11:14:53.536 Saved Chartbook: SpotGammaES.Cht. Time: 0.0008 seconds. | 2021-07-17 11:15:44.943 Saved Chartbook: ES_5.Cht. Time: 0.0342 seconds. | 2021-07-17 11:15:44.979 ESU21_FUT_CME [CV][M] 15 Min #24 | Reloading chart. | 2021-07-17 11:40:23.045 ESU21_FUT_CME 1 Min #21 | Reloading chart. | 2021-07-17 11:41:14.564 ESU21_FUT_CME[M] 1 Min #21 | Study: SpotGamma | Making HTTP request. | 2021-07-17 11:41:15.560 Error getting address info for spotgamma-system-https. Windows error code 11001: No such host is known. | 2021-07-17 11:41:20.781 * Chart: ESU21_FUT_CME[M] 1 Min #21 | Study: SpotGamma | [debug] [6897] 2021-07-17 11:41:20.000 -- (4318.500000) Downloaded Data: | 2021-07-17 11:41:20.782 Chart: ESU21_FUT_CME[M] 1 Min #21 | Study: SpotGamma | [debug] [6897] 2021-07-17 11:41:20.000 -- (4318.500000) HTTP_REQUEST_ERROR | 2021-07-17 11:41:20.782 Chart: ESU21_FUT_CME[M] 1 Min #21 | Study: SpotGamma | [info] [6897] 2021-07-17 11:41:20.000 -- (4318.500000) Adding levels | 2021-07-17 11:41:20.782 Warning: The Custom DLL study "sierra-chart-driver-v2.scsf_SpotGamma" has just caused a CPU exception. | 2021-07-17 11:41:20.782 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from the chart and restart Sierra Chart. | 2021-07-17 11:41:20.782 * ESU21_FUT_CME[M] 1 Min #1 | Study: SpotGamma | Making HTTP request. | 2021-07-17 11:41:38.807 Saved Chartbook: SpotGammaES.Cht. Time: 0.0024 seconds. | 2021-07-17 11:41:38.808 Saved Chartbook: ES_5.Cht. Time: 0.0342 seconds. | 2021-07-17 11:41:38.843 Error getting address info for spotgamma-system-https. Windows error code 11001: No such host is known. | 2021-07-17 11:41:39.849 * Chart: ESU21_FUT_CME[M] 1 Min #1 | Study: SpotGamma | [debug] [6897] 2021-07-17 11:41:39.000 -- (4318.500000) Downloaded Data: | 2021-07-17 11:41:39.850 Chart: ESU21_FUT_CME[M] 1 Min #1 | Study: SpotGamma | [debug] [6897] 2021-07-17 11:41:39.000 -- (4318.500000) HTTP_REQUEST_ERROR | 2021-07-17 11:41:39.850 Chart: ESU21_FUT_CME[M] 1 Min #1 | Study: SpotGamma | [info] [6897] 2021-07-17 11:41:39.000 -- (4318.500000) Adding levels | 2021-07-17 11:41:39.850 Warning: The Custom DLL study "sierra-chart-driver-v2.scsf_SpotGamma" has just caused a CPU exception. | 2021-07-17 11:41:39.850 * Warning: This Custom DLL study may cause Sierra Chart to be unstable until you remove the study from the chart and restart Sierra Chart. | 2021-07-17 11:41:39.850 * |
[2021-07-20 21:28:45] |
just a follow up, the levels update once and get pulled into the platform, but instead of updating intraday like they should, they do not adjust.
[2021-07-21 04:17:01] |
The exceptions are definite real problem. And you do not want to use a study which is causing those.
