Date/Time: Wed, 08 May 2024 00:42:27 +0000
Chart Setting
View Count: 936
[2014-03-18 21:59:01] |
User41116 - Posts: 10 |
Hi, Can you please point to the literature re the setting I have activated, and what the numbers refer to. Refer to the image at the link below, marked with a green arrow. http://www.sierrachart.com/image.php?l=1395179791830.png Thanks |
[2014-03-18 22:19:17] |
This is documented here: https://www.sierrachart.com/index.php?l=doc/doc_TradeMenu.html#DrawDOMGraph Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
