Date/Time: Fri, 03 May 2024 00:48:27 +0000
[User Discussion] - ZIG ZAG CUMULATIVE VOLUNME COLOR BAR
View Count: 1265
[2014-03-18 21:23:55] |
User31737 - Posts: 73 |
I am trying to set up a simple study using the color bar alert or color bar above below study to color the main chart candle green when the accumulated volume of the zigzag cumulative study is > 0, and red when the accumulated volume is < 0. I do not want them colored based on the swing, but, rather the above 0(positive delta), and below zero for negative delta. I tried it as an alert condition with the following in the alert: = C > 0 I've also tried it this way =ID3.SG5 > 0, =ID3.SG5 < 0 and I also used a 1 period SMA of the Accumulated volume bar graph to try and read that as an above/below study, but without the result I wanted. Any suggestions? Date Time Of Last Edit: 2014-03-18 21:58:28
[2014-03-18 22:09:14] |
SOLVED it works this way =ID3.SG5 > 0 (alerts condition Box, ID3.SG5 is the appropriate study ref) Use -1 on False checked to yes (settings and inputs tab) based on +/- color selected in subgraphs Date Time Of Last Edit: 2014-03-19 00:08:30
