Date/Time: Sun, 19 Apr 2026 21:23:40 +0000
Is it possible to save worksheet studies as actual studies?
View Count: 2509
| [2013-04-22 18:04:12] |
| pe1111112 - Posts: 35 |
I've made some worksheet studies (for example, identifying candle formations), and I know how to save the worksheet, but I have trouble applying them to other charts because the values don't always populate and the data is on a different tab in the spreadsheet, etc. Is there a way to save the current worksheet study on the active chart and then apply it to another active chart? I don't know C++ or whatever code language SC uses so that's not really an option. |
| [2013-04-22 19:38:25] |
Yes. This can be easily done through Study Collections. Please see this page: http://www.sierrachart.com/index.php?l=doc/doc_StudyCollections.html You will need to go to the chart that contains the Spreadsheet study set up the way that you want and save all of the studies including the Spreadsheet study as a study collection and then you can apply it to any other chart. One thing to consider though is that for this to work properly the Chart Data Output Sheet Number input with the Spreadsheet Study needs to be set to 0. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-22 19:45:03
