Date/Time: Sun, 28 Apr 2024 19:09:49 +0000
Ellipse modification
View Count: 639
[2021-07-08 07:29:33] |
AndreyPoroshin - Posts: 102 |
I propose to change for the better the possibility of drawing an ellipse shape. The ellipse is used for Gann analysis and is only useful when drawn at random. Now, as it is implemented, it does not make any sense, Ellipses are now drawn only vertically and horizontally. I gave an example from the AMPquantower platform. I thank you in advance! Date Time Of Last Edit: 2021-07-27 09:10:16
Ellipse.wmv - Attached On 2021-07-08 07:28:53 UTC - Size: 11.53 MB - 185 views |
[2021-07-17 06:18:02] |
Hello, I am updating my question, as it probably passed by your attention.
Date Time Of Last Edit: 2021-07-17 06:18:42
[2021-07-23 09:21:09] |
We will have a look at this when we can.
[2021-08-11 12:37:37] |
This has been implemented (Angled Ellipse). It is a new drawing tool. The initial implementation is in the latest prerelease. Instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-11 12:43:18
[2021-08-13 06:58:48] |
Thank you for your prompt work! You are cool! I liked the preliminary testing of the angular ellipse and I'm sure other users will appreciate this improvement.
2021-08-13_025317.png / V - Attached On 2021-08-13 06:58:28 UTC - Size: 53.55 KB - 163 views |
[2021-11-30 11:34:37] |
Please tell me if it is possible to correct the display of the calculator result? The fact is that the counting is carried out in calendar days and does not exclude weekends. for example: $ INX in one trading day 6.5 hours. I would like to see the calculator display not only in bars, trading days, but also in trading hours (= Day * 6.5). If it is difficult because of the different duration of sessions in the markets, then it will be enough to accurately display the number of trading sessions in the calculator, but not calendar days. Thank you in advance. |
2021-11-30_112330.png / V - Attached On 2021-11-30 11:34:15 UTC - Size: 7.22 KB - 122 views |
[2021-11-30 16:07:51] |
We have set this as a Feature Request. Also, a post like the last one should be done in it's own thread and not added to this already Resolved thread that was about something completely different. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-11-30 17:12:20] |
OK! thanks! I'll take note for the future. Please transfer if necessary.
