Date/Time: Mon, 06 May 2024 00:24:06 +0000
India Stocks Datafeeed
View Count: 760
[2021-07-05 16:16:54] |
NJ - Posts: 20 |
Hi I am trying to use the Standard Service Pack 3 and get the Indian Stocks Historical End of Day Data Feed. However it is somehow coming only till Jan 2021 only. Please can u check the attached screenshot and suggest whats wrong. Also, When I click on "Edit --> 'Delete all data & Download' it gives me this error "Download Failed. Error Downloading Historical End Of Day Data for Lupin.NS Error executing query: User is not authorized to execute query for one or more of the specified symbols" Regards https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=52433 |
[2021-07-05 18:59:01] |
Sierra_Chart Engineering - Posts: 14238 |
We have requested authorization for this data from our data provider. When it becomes available, then you need to select Edit >> Download Data for all Historical Charts. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-07-05 18:59:34
[2021-07-06 03:56:03] |
NJ - Posts: 20 |
Hi Sierra Chart Team, Thank you for your response. Any idea by when would the Authorisation happen. Would you be able to inform here once its fixed or should I keep checking from my side. Regards, NJ Date Time Of Last Edit: 2021-07-06 03:56:25
[2021-07-07 18:23:10] |
NJ - Posts: 20 |
Hi Sierra Team, Just FYI - The status is still the same for now. Am assuming the data provider has not fixed the issue yet :-( Regards NJ |
[2021-07-15 18:25:46] |
NJ - Posts: 20 |
Sierra Team - The India stock feed data is not yet activated. Is there any timeline to this please?? Kindly advise Regards Nitin |
[2021-07-15 21:30:10] |
We did check on this. This Indian exchange data is just no longer going to be available from Sierra Chart. We would have to work on another source but that is not something we can do in the short term.
[2021-07-16 02:55:39] |
NJ - Posts: 20 |
Oh ok. What is the other source. I have used Global Data Feeds in the past but that doesn't work at all as it keep getting disconnected and they were quite expensive. Any other feeds that can be explored. You should certainly add India Data feed from Sierra Chart. Sierra Chart is a great software and I have used others too. Just for the lack of Indian data feed, there are many traders from India not being able to use Sierra Chart. Regards Nitin |
