Date/Time: Wed, 01 May 2024 02:57:08 +0000
Bitcoin Volume @ Bid/Ask Reversed?
View Count: 2358
[2013-04-22 17:19:09] |
bfalk - Posts: 33 |
I'm using Ask/Bid volume difference bars, and it seems like for Bitcoin the ask/bid volume numbers are reversed. I'm only judging by the fact that when there's a huge selloff, I get more @bid volume than @ask volume. -Brandon |
[2013-04-22 19:27:15] |
We will check on this. But it could just have to do with how the Bitcoin source data feed works.
[2013-04-22 21:30:19] |
This actually makes sense because when the market declines, there will be more bid volume.
[2013-04-22 21:39:16] |
bfalk - Posts: 33 |
I guess it's just different than I'm used to. AAPL from IQFeed, EURUSD from you guys, and BTCUSD from you guys. Notice how BTCUSD is different than the others when there's selling. http://i.imgur.com/XnrHMPs.png |
[2013-04-24 20:38:04] |
We know the source of the problem now. This will be corrected in the next couple of days. But you will have to re-download all of the historical data with Edit >> Delete All Data and Download after the data is reloaded on the server.
