Date/Time: Mon, 06 May 2024 21:30:47 +0000
Tick charts
View Count: 1181
[2014-03-17 12:56:45] |
kirstenjd - Posts: 34 |
How do I get a 1,000 tick chart. I have only been using minute charts. When I go to Chart>>Chart Settings >> ........, I can not see where to select tick charts e.g. 1000 tick chart for ES. |
[2014-03-17 14:05:05] |
mkata - Posts: 103 |
Chart>>Chart Settings >> Bar Period >> Number of Trades per Bar. (this is your tick chart) |
[2014-03-17 16:52:02] |
Refer to the documentation for this here: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#TimePeriodPerBar Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
