Date/Time: Sat, 04 May 2024 05:07:38 +0000
Extra Volume Bars
View Count: 924
[2014-03-17 10:57:50] |
User63042 - Posts: 19 |
Hi. I am using 377 volume bars on EURUSD pair, data from SC Forex (FXCM). In real time there are additional bars printed, minimal volume (2 or 3), very small about 1 tick - see attached file. The bars appear randomly. If I edit the intraday data by deleting a couple of days then sometimes the extra bars disappear. My clock is in sync. I have tried volume per bar and trades per bar - same result. It's a problem because it throws out all drawings. Regards.
EURUSD extra volume bars.bmp - Attached On 2014-03-17 10:53:47 UTC - Size: 7.24 MB - 347 views |
[2014-03-17 15:05:26] |
I have found that editing the intraday data always removes the extra bars (I wasn't doing this correctly)
[2014-03-17 15:24:58] |
I think I have worked this out. I had two instances of SC both using the same EURUSD file. Hence the extra data.
[2014-03-17 16:51:00] |
Good thing you figured this out. Otherwise, it would be hard for us to understand what was going on. In many cases, users are much better able to resolve their own problems by taking the time to understand what they are doing and referring to the documentation because really they have more details about an issue than we do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
