Date/Time: Mon, 21 Sep 2026 12:27:47 +0000
Deribit Data stopped
View Count: 935
[2021-07-01 15:18:03]
User315643 - Posts: 10
All other crypto data is working fine, however Deribit has stopped in the SC All Services Data.
Can this be fixed?
Thanks.
[2021-07-01 16:16:52]
John - SC Support - Posts: 47939
We are not seeing an issue with BTC-PERPETUAL-DBIT.
Are you still having an issue?
What symbol are you looking at?
[2021-07-02 00:24:56]
Earlier today, Deribit did have a problem with their servers.
[2021-08-30 17:25:51]
User101680 - Posts: 11
hey,
quick follow up on this issue..
i have version 2299 runing...and i get no deribit symbols displayed on the "find symbol" tab
i know that y had deribit data feeds in the past...is this a matter of the version i run? or did y stop providing the dat feed altogehter?
Tia
best reagard
[2021-08-31 14:39:45]
Since your Service is set to Bitmex Trading, you will not see the other data options. If you want/need to keep your service set to Bitmex, then the easiest thing to do is to install a second Sierra Chart and set the Service to SC Data - All Services (the default) and then you will have access to the other data, including Deribit.
Refer to the following for how to install a second Sierra Chart (there are no additional charges for having a second Sierra Chart installation):
Using Multiple Data and Trading Services at the Same Time
[2021-09-01 05:19:21]
Hey John,
oohh...i see...thats the issue..THX a lot for pointing that out..will do so
