Date/Time: Sun, 05 May 2024 10:52:01 +0000
ES rollover
View Count: 1189
[2014-03-17 08:11:05] |
Trakot57 - Posts: 8 |
Hi Sierra, I use infinity + Sierra chart. On the 1st chart there is simple ESM4 chart (without premarket). On the 2nd chart is ESM4 [CB] chart. This 2nd chart is the same after performing futures rollover. Until 12.3.2014 all candles should be down by 7 points (as on the 1st chart), but they are not. I can`t perform rollover due to this, and don`t know what to do. Please help. I have version 1107. Paul |
[2014-03-17 08:19:53] |
If you want continuous back adjusted data, then you need to enable that in each and every one of your charts where you want that. Here are the instructions: https://www.sierrachart.com/index.php?l=doc/doc_ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-17 10:02:07] |
Like I mentioned that back adjusting does not work and after enabling, it still looks like on the 2nd chart without automatic adjustement
[2014-03-17 14:45:21] |
will this help you to help me somehow? ESM4 [CB] 30 Min #21: ESH4 price difference to ESM4 is 0. | 2014-03-17 09:38:26 ESM4 [CB] 30 Min #21: Back adjust amount for symbol ESH4 is 0. | 2014-03-17 09:38:26 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13 | 2014-03-17 09:42:03 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12 | 2014-03-17 09:42:03 Checking Intraday data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13 | 2014-03-17 09:42:03 Daily data file for symbol ESH4 existed and is empty. Skipping download. | 2014-03-17 09:42:03 Checking Intraday data file for symbol ESM4 for the date range from 2014-03-13 to 0 | 2014-03-17 09:42:03 Daily data file for symbol ESM4 existed and is empty. Skipping download. | 2014-03-17 09:42:03 Symbols used for ESM4 continuous contract chart: | 2014-03-17 09:42:03 ESH4 | 2014-03-17 09:42:03 ESM4 | 2014-03-17 09:42:03 ESM4 [CB] 30 Min #21: Performing continuous futures contract back adjustment calculations. | 2014-03-17 09:42:03 Error while getting daily open price with date 2014-03-16 from file. C:\SierraChart\SierraChartTransActMA\Data\ESH14.dly. Error: Encountered end of file. | 2014-03-17 09:42:03 Error while getting daily open price with date 2014-03-16 from file. C:\SierraChart\SierraChartTransActMA\Data\ESM14.dly. Error: Encountered end of file. | 2014-03-17 09:42:03 ESM4 [CB] 30 Min #21: ESH4 price difference to ESM4 is 0. | 2014-03-17 09:42:03 ESM4 [CB] 30 Min #21: Back adjust amount for symbol ESH4 is 0. | 2014-03-17 09:42:03 Date rule based rollover from ESH4 to next contract occurs at 2014-03-13 | 2014-03-17 09:42:21 Date rule based rollover from ESM4 to next contract occurs at 2014-06-12 | 2014-03-17 09:42:21 Checking Intraday data file for symbol ESH4 for the date range from 2013-12-12 to 2014-03-13 | 2014-03-17 09:42:21 Daily data file for symbol ESH4 existed and is empty. Skipping download. | 2014-03-17 09:42:21 Checking Intraday data file for symbol ESM4 for the date range from 2014-03-13 to 0 | 2014-03-17 09:42:21 Daily data file for symbol ESM4 existed and is empty. Skipping download. | 2014-03-17 09:42:21 Symbols used for ESM4 continuous contract chart: | 2014-03-17 09:42:21 ESH4 | 2014-03-17 09:42:21 ESM4 | 2014-03-17 09:42:21 ESM4 [CB] 30 Min #21: Performing continuous futures contract back adjustment calculations. | 2014-03-17 09:42:21 Error while getting daily open price with date 2014-03-16 from file. C:\SierraChart\SierraChartTransActMA\Data\ESH14.dly. Error: Encountered end of file. | 2014-03-17 09:42:21 Error while getting daily open price with date 2014-03-16 from file. C:\SierraChart\SierraChartTransActMA\Data\ESM14.dly. Error: Encountered end of file. | 2014-03-17 09:42:21 ESM4 [CB] 30 Min #21: ESH4 price difference to ESM4 is 0. | 2014-03-17 09:42:21 ESM4 [CB] 30 Min #21: Back adjust amount for symbol ESH4 is 0. | 2014-03-17 09:42:21 Date Time Of Last Edit: 2014-03-17 14:51:40
[2014-03-17 16:28:54] |
Select File >> Open Historical Chart. Delete the following files: ESH14.dly ESM14.dly After this go to your charts which do not have the right back adjustments and select Chart >> Reload and Recalculate. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-17 16:45:17] |
It works! You are the best ! Thank You very much |
