Date/Time: Mon, 29 Apr 2024 09:18:57 +0000
[User Discussion] - Not able to connect to Rithmic demo
View Count: 1018
[2014-03-17 06:54:26] |
Carl71 - Posts: 125 |
Rithmic Trading - Port for executable: 44480 | 2014-03-17 06:57:11 Rithmic Trading - Starting server: C:\SierraChart\Rim\DTCBridge.exe | 2014-03-17 06:57:11 Rithmic Trading: Connecting to the server 127.0.0.1. Port 44480 | 2014-03-17 06:57:13 The network socket is connected. | 2014-03-17 06:57:13 Rithmic Trading: Connected to server. | 2014-03-17 06:57:13 Rithmic Trading: Sending logon request message. | 2014-03-17 06:57:13 Rithmic Trading - Starting the connection process to data and trading service. | 2014-03-17 06:57:13 Rithmic Trading - Logging is enabled. Log file: Rithmic.log | 2014-03-17 06:57:13 Rithmic Trading - Connecting to Rithmic Paper Trading server. | 2014-03-17 06:57:13 Rithmic Trading - Server Alert: Market Data Connection Opened | 2014-03-17 06:57:15 Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 06:57:16 Rithmic DTC Server Info - Server Name: SC DTC Bridge. Server Version: 1.1. Provider Name: Rithmic DTC. | 2014-03-17 06:57:16 Rithmic DTC - Server protocol version: 3. Client protocol version: 3. There is a protocol match. | 2014-03-17 06:57:16 Rithmic DTC - Logon error from server | 2014-03-17 06:57:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 06:57:16 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 06:57:16 Rithmic DTC: Disconnected from the server. | 2014-03-17 06:57:16 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 06:57:16 Rithmic DTC: Bridge process is still running. Not able to connect. | 2014-03-17 06:57:18 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 06:57:18 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 06:57:18 Rithmic DTC: Disconnected from the server. | 2014-03-17 06:57:18 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 06:57:18 Rithmic DTC: Bridge process is still running. Not able to connect. | 2014-03-17 06:57:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 06:57:20 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 06:57:20 Rithmic DTC: Disconnected from the server. | 2014-03-17 06:57:20 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 06:57:20 Rithmic DTC: Bridge process is still running. Not able to connect. | 2014-03-17 06:57:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 06:57:22 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 06:57:22 Rithmic DTC: Disconnected from the server. | 2014-03-17 06:57:22 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 06:57:22 Rithmic DTC: Bridge process is still running. Not able to connect. | 2014-03-17 06:57:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2014-03-17 06:57:24 To prevent further connection attempts, select 'File >> Disconnect'. | 2014-03-17 06:57:24 Rithmic DTC: Disconnected from the server. | 2014-03-17 06:57:24 Will reconnect to the server in 2.0 seconds Select File >> Disconnect to prevent further connection attempts. | 2014-03-17 06:57:24 File >> Disconnect selected. | 2014-03-17 06:57:25 Rithmic DTC: Disconnected from the server. | 2014-03-17 06:57:25 Date Time Of Last Edit: 2014-03-17 06:58:14
[2014-03-17 07:55:04] |
We no longer provide help with this: Rithmic Trading - Server Alert: Market Data Connection Login Failed. Result text: "permission denied" | 2014-03-17 06:57:16 Either ask your broker for help. However, it is unlikely you will be able to connect. Or use a Live Rithmic account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
