Date/Time: Sun, 29 Nov 2026 00:15:42 +0000
How to apply commas and periods to make results much easier to read?
View Count: 743
| [2021-06-28 12:30:11] |
| The Stealthy Trader - Posts: 190 |
I've noticed that the default appearance of any data output is seeing a string of numbers..Ex: Volume for ABC: 15343535 My ability to better interpret this data in both the Chart Value Window or represented in Spreadsheet Study would be to format it with commas/periods..So, for the above example I would prefer 153,435.35 This is way easier to read.. Is there a global setting to accomplish this? Any thoughts? |
| [2021-06-28 15:04:16] |
The only option is the Large Integer with Suffix, which is available as a Value Format for some studies, and is a specific Input for some other studies (such as Numbers Bars). Refer to the following: Chart Studies: Settings and Inputs Tab >> Value Format For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
