Date/Time: Mon, 06 May 2024 00:05:43 +0000
OEC integration
View Count: 1821
[2013-04-22 16:14:36] |
levakm - Posts: 1 |
Hi, I wanted to ask where unfilled orders a held when Sierra chart is integrated with OEC. Does Sierra populate orders on OEC's servers or they are held in the platform. Thank you, Michal |
[2013-04-22 16:20:01] |
They are sent immediately to OEC except in the case of child Attached Orders before the Parent order is filled: http://www.sierrachart.com/index.php?l=doc/doc_AttachedOrders.html#Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2013-04-22 16:20:17
