Date/Time: Fri, 03 May 2024 16:41:00 +0000
New FairX exchange access?
View Count: 1411
[2021-06-25 14:42:06] |
TriStar Trading - Posts: 113 |
Any plans for a hookup to the new FairX exchange? I use Denali.
[2021-06-28 06:11:21] |
Sierra_Chart Engineering - Posts: 14202 |
We will have to see about this later.
[2021-07-21 06:54:16] |
User981226 - Posts: 3 |
FairX is already supported by several brokers and is supported by CQG. I'm actually very interested in using it myself, particularly now while the fees are free for the rest of the year. I actually didn't renew my services a few weeks ago as I was focused on working the FairX stuff. I'd love to keep using SC as I have for automated trading for many years. I see it on the CQG side but couldn't get SC to accept it as a symbol. Is there a restriction on allowing FairX exchange with CQG? I was hoping you would just receive/pass it through to/from CQG just like any other future instrument on CQG. |
[2021-08-02 18:35:08] |
TropicalTrader - Posts: 35 |
Any updates on FairX?
[2021-08-12 16:46:20] |
I guess the silent treatment is the equivalent of a "No, we aren't going to add FairX exchange."?
[2021-08-12 16:47:33] |
Market data from FairX will be coming next week. We hope to finish it then. But probably still another week or so after for actual release. We definitely are going to be very supportive of that exchange. Sorry for the delayed response. I see it on the CQG side but couldn't get SC to accept it as a symbol. Is there a restriction on allowing FairX exchange with CQG?
We have not specifically added symbols for this exchange on CQG, but you can just manually specify the symbols and they will work. They do pass through without any need for translation from us.
I was hoping you would just receive/pass it through to/from CQG just like any other future instrument on CQG. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-12 16:48:25
[2021-08-24 12:27:36] |
Pawel_Szpak - Posts: 48 |
Hi, any update on this?
[2021-08-24 14:13:47] |
This is still in progress.
[2022-02-18 04:32:21] |
ertrader - Posts: 645 |
I see FairX has been supported for the last several releases. A few questions: 1) What are the steps to be able to trade on Fairx? 2) Is Denali historical data supported with FairX? 3) What have been traders experiences with FairX? Execution speed, slippage, costs, volume etc. 4) Volume looks low for most instruments (from their website links to daily volume), do you or any traders have examples of footprint charts/Volume Profiles etc.? 5) Is MBO data supported? Date Time Of Last Edit: 2022-02-18 04:47:27
[2022-02-18 16:32:22] |
John - SC Support - Posts: 31351 |
1. Follow the instructions for the Teton Exchange Data Feed: Sierra Chart Teton Futures Order Routing: Setup Instructions 2. Yes. 3. Others will have to answer this. 4. Others will have to answer this. 5. Yes. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
