Date/Time: Wed, 01 May 2024 21:16:41 +0000
Delayed Eurex data / Switching to Sierra order routing service
View Count: 491
[2021-06-21 22:19:47] |
Chris_uk - Posts: 89 |
Apologies for bothering you again! Currently using Denali with CQG, I have activated CME data and will activate Eurex data at the beginning of July. I am in the process of moving away from CQG to use the Sierra order routing service, after the ridiculous situation that occurred today with the CQG margin issues. Am I right in saying that I will have to leave Amp in order to do this? Is it possible to get delayed Eurex Data in the meantime? I get the error in the screenshot below. http://www.sierrachart.com/image.php?Image=1624313535161.png Similar appears in the message log. Do I need to use a second instance for the delayed Eurex data? Many Thanks |
[2021-06-22 13:16:27] |
John - SC Support - Posts: 31283 |
You will need to leave AMP for a different broker to use the existing Sierra Chart Order Routing Service. But with the new Direct CME Order Routing that we are working on, we hope to have AMP work with it, but we do not know for sure whether that will happen or not. Do I need to use a second instance for the delayed Eurex data?
Yes, you need to have another installation of Sierra Chart where the service is set to SC Data - All Services. The way the system is setup, is that uses any real-time data that you get from us first, then it looks to your trading/data service for any other data. Therefore, since you are setup with CQG, it is looking to get the EUREX data from CQG, for which you are not authorized. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-22 22:41:33] |
Thanks! I may just wait in that case, do you also plan to work with AMP on the Direct Eurex Order Routing too? Kind Regards |
[2021-06-23 13:39:05] |
We certainly hope to, but we can't make any promises, as it is also up to AMP. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
