Date/Time: Mon, 06 May 2024 03:38:47 +0000
Numbers Bars Accuracy - volume information
View Count: 575
[2021-06-21 18:45:33] |
user08187 - Posts: 15 |
Hi In the attached image, I used both Number Bars and Number Bars calculated values studies on the feed from Global Data Feeds. 1 lot size for symbol NIFTY-I.NFO, is 75. So, any volume related information on the display should be multiples of 75. But in both the above studies, not all volume related information are multiples of 75. I had even set Intraday Data Storage Time unit as 1 Tick, and Number of Days to load as 2. For example, Bid Vol|Ask Vol for 15751.00 at 15:25 is 1275|4351, where 4351 is not a multiple of 75. The attached image is only an example and is not of live trade data, but above mentioned volume inaccuracy is same in live trade data too. Could you please let me know, how it could be fixed. Thanks |
SC - Number Bars Accuracy - volume.jpg / V - Attached On 2021-06-21 18:39:12 UTC - Size: 120.19 KB - 219 views Attachment Deleted. |
[2021-06-21 19:56:52] |
John - SC Support - Posts: 31379 |
You would have to ask Global Data Feeds what they are sending in that information.
[2021-07-21 09:17:04] |
Hi Global Data Feeds updated me as "whenever there is Zero Volume in a particular tick, SierraChart shows 1 in Volume column; and if we select “ Hide Zero Volume “ from nimbledataPlusLite dashboard and it will not show 1 volume column." I did as told by Global Data Feeds, and now everything works fine. Thanks |
SierraChart.jpg / V - Attached On 2021-07-21 09:15:53 UTC - Size: 329.2 KB - 166 views |
