Date/Time: Sun, 28 Apr 2024 14:05:39 +0000
anfrage: ich habe einen account und möchte künftig die tpo nut
View Count: 352
[2021-06-14 16:32:14] |
bernhard windisch - Posts: 1 |
was kostet das monatliche packet wo ich tpos analysieren kann und wie aktiviere ich das wenn ich das geld überwiesen habe? ich habe momentan den datenfeed bei whselfinvest ...kann ich dann sierra chart über diesen brocker nutzten, oder habe ich dann nur immer die verzögerten daten im sierra chart? |
[2021-06-14 18:35:56] |
From Google Translate: what does the monthly packet cost where i can analyze tpos and how do i activate it once i have transferred the money?
i currently have the data feed at whselfinvest ... can i then use sierra chart via this broker, or do i just always have the delayed data in sierra chart? In order to use the TPO charts, you would need to have the Advanced Package. The cost for this without the data feed is $36.00 USD per month. For more information on the packages and their pricing, refer to the following: Description of Service Packages and Pricing: Packages In terms of WH SelfInvest, we would need to know what order routing service they are working with. Once we know what order routing service they are using, then we can direct you as to how to get setup and what to do about data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
