Date/Time: Mon, 26 Oct 2026 20:22:21 +0000
Chart & spreadsheet not functioning in 2nd instance
View Count: 730
[2021-06-14 12:38:07]
BenjaminR - Posts: 185
I opened a 2nd instance, & opened a chartbook from the Main Sierra Chart data folder, that contains a chart that uses a spreadsheet study, as well as 2 "study/chart overlay" studies. The formulas in the spreadsheet were missing, & the "study chart overlays" were no longer listed in the chart's studies.
Next, I went to directly to the main SC data folder, found the chartbook, copied & pasted it from the main SC data folder, directly into the 2nd instance data folder. I then opened it from there directly. Same issue.
Is there something I am missing about spreadsheet studies, that they can't be moved like this? Is there a second file in the data folder I also need to move to the 2nd instance data folder?
Please advise.
Thank you!
[2021-06-14 16:21:05]
John - SC Support - Posts: 48333
You also need to copy the .scss file that is the Spreadsheet file. Refer to the following information to know the name of the file:
Chart Studies: Settings and Inputs Tab >> Spreadsheet Name / DLL File and Function Name
