Date/Time: Fri, 19 Aug 2022 18:02:58 +0000
rollover problem
View Count: 667
[2014-03-14 13:06:27] |
Dennis B. - Posts: 219 |
Switched from March es to June and I can't get day session charts, all charts stuck in evening full session mode..help! Running version 1107. Thanks... |
[2014-03-14 16:31:01] |
This is probably because the Session Times were reset. The solution to this can be found here: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes You will need to set the Session Times as you require: https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#SessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
