Date/Time: Wed, 08 May 2024 02:21:09 +0000
Text on ext Rect
View Count: 1378
[2014-03-14 07:01:26] |
AKR - Posts: 523 |
this is for sure a minor problem, but probably easy to solve. the text of extend rect seems to me randomly be on the top or bottom of it. Is there a way to always keep it same. when having many of them overlaying each other this can be a bit confusing. thx!! |
[2014-03-14 07:07:00] |
We will look into this.
[2014-03-14 12:51:14] |
Al SC Developer - Posts: 434 |
The labels are always placed outside the rectangle (one above and one below). This is done so the text is easier to read by not being within the highlight area, but obviously multiple overlapping drawings interferes. If you have a drawing that does not have text outside, please post an image. We will look at adding an option to control the vertical alignment of the labels. |
[2014-03-14 12:56:28] |
AKR - Posts: 523 |
yes, it is outside the rectangle always, true. but sometimes it is on the upper outside and sometimes on the lower outside..... what do you mean with "one above and one below". I eg only use text, there is no price label. but for some rectangles (expanding rectangle that usually is cut at the left side somewhere) as I said it is above and sometimes belwo. and I do not know how to control that.... thanks a lot! |
[2014-03-14 13:03:27] |
When price is displayed there are two labels (one above/below). When only the text is displayed, it is currently drawn based on how the rectangle was drawn (2nd point above/below first). We will change this to be more consistent and always put on top.
[2014-03-14 14:19:33] |
AKR - Posts: 523 |
ah, I see. great & thx for solution !!! |
