Date/Time: Sun, 28 Apr 2024 18:25:20 +0000
DTC ctwo versions of SC - possible?
View Count: 395
[2021-06-11 09:12:50] |
User308424 - Posts: 68 |
Hi there, I would like to know if it is possible to have one instance of SC acting as server (this will be old version because I want to run Rithmic connection) and one or more instances on up-to-date versions which will receive data from server instance running on Rithmic? Thanks in advance! |
[2021-06-15 08:49:06] |
Sierra_Chart Engineering - Posts: 14121 |
Yes. This should work unless the differences between versions are too significant and there is some protocol compatibility issue.
