Date/Time: Fri, 03 May 2024 13:10:34 +0000
Activity log
View Count: 1453
[2014-03-14 06:56:49] |
AC94898 - Posts: 1 |
Hello guys, Im trading on Sierra, but in Trade activity log is no data. I trade on sim account, yesterday I had one trade but Im not able to export trade activity, can you help? See attached screenshot https://www.dropbox.com/s/zgu4iaqcpf1ftbi/sierra-activity-log.PNG Thank you |
[2014-03-14 07:06:28] |
Just to the left of the box that says "All Accounts", is the list of Symbols. Choose the symbol you have traded. It will have [Sim] in front of it.
[2014-03-14 07:40:11] |
User94740 - Posts: 333 |
Hi SC, I am having this same problem and have done as described above, but it still fails to show anything.
[2014-03-14 07:41:45] |
PS it is showing nothing for my simulated as well as live account
[2014-03-15 01:29:40] |
vegasfoster - Posts: 444 |
Have you selected a symbol from the middle drop down box? If not, select All Symbols or the desired symbol.
[2014-03-15 02:57:59] |
Here are the instructions to use the Trade Activity Log: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php You should not have a problem viewing Order Activity for orders entered directly from Sierra Chart. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-03-20 23:40:10] |
Hi SC, I have to wonder if I am doing something wrong. The trade window shows no activity, but ... the orders and positions window shows activity. Below is a screenshot of my desktop. thx for the help! http://www.sierrachart.com/image.php?l=1395358782384.png |
[2014-03-21 09:33:23] |
Refer to step 5 here: https://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
