Date/Time: Sat, 04 May 2024 00:44:04 +0000
Session breaks on chart
View Count: 664
[2021-06-10 23:55:23] |
countryboy92 - Posts: 90 |
I would like to add the session breaks on my chart that look like vertical lines (usually formatted as a dotted line). I would like the session break to be at the 6pm open of the new trading session, and I have set up my session format to start at 6pm and end at 5pm the following day. The session end indicator I found plots a horizontal line, but I need a vertical line that goes through the 6pm candle.
[2021-06-11 01:28:45] |
58LesPaul - Posts: 429 |
You need the Time Line study and set the time at 18:00:00
[2021-06-11 08:47:01] |
Refer to: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
