Date/Time: Sun, 05 May 2024 08:40:07 +0000
Volume above/below a certain price
View Count: 605
[2021-06-08 22:58:26] |
User288938 - Posts: 30 |
Hey, Just wondering if there was a way to find the volume in globex above/below previous RTH close price. So the overnight inventory essentially. I've had a run through the support boards and can't seem to find a solution cheers |
[2021-06-09 03:05:25] |
The closest available is to use the Volume by Price study which does calculate the volume above and below the Point of Control for a period of time.
[2022-05-20 13:30:34] |
dvant krypto - Posts: 42 |
I think it's time for SC to seriously consider an Overnight Inventory Long/Short % study
