Date/Time: Wed, 15 May 2024 02:29:42 +0000
DMI indicator in histogram
View Count: 522
[2021-06-07 10:04:29] |
User267907 - Posts: 17 |
Hello, How to make the DMI indicator in histogram ?? That is to say that the crossing of 2 lines is done with respect to 0. Thank you for your answer Alain. |
example MACD.jpg / V - Attached On 2021-06-07 09:51:16 UTC - Size: 85.71 KB - 207 views |
[2021-06-09 18:07:14] |
User90125 - Posts: 715 |
Keep it simple. Just use the Directional Movement Oscillator instead. Change the DMI Diff Draw Style to Transparent Fill to Zero. |
[2021-06-09 20:10:02] |
Thank you so much user 212764. I was using the directional index movement. And yet the oscillator is just below in the list. It's just what I wanted. Thank you so much 👍👍👍 |
[2021-06-11 20:57:46] |
No problem. Glad I could help out.
