Date/Time: Mon, 06 May 2024 05:15:51 +0000
Microsoft NET4
View Count: 994
[2014-03-13 18:35:18] |
Dennis B. - Posts: 263 |
Installed NET 4 on my winxp pc, Causing some start-up problems. If I uninstall it will it affect SC ? Have NET3 already. Thanks... |
[2014-03-13 20:53:38] |
Not if you run the non-CLR version of Sierra Chart which you can obtain by selecting Help >> Download Latest Non-CLR Version. The only limitation is that the Spreadsheets in that version are still under development. It is preferred that users use the non-CLR version at this time if they do not require spreadsheets. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
