Date/Time: Mon, 06 May 2024 16:18:34 +0000
Vertical line at time instead of horizontal?
View Count: 838
[2021-06-05 11:23:06] |
HeyUgly - Posts: 233 |
trying to lay out time based lines, every 30mins a vert line on a smaller time frame chart say a 1min, is this possible? so at the close of every 30min bar a vertical line appears on the chart?
[2021-06-06 10:05:31] |
58LesPaul - Posts: 429 |
yes, use the time line study. Time Line |
[2021-06-06 12:12:25] |
User907968 - Posts: 802 |
Another option is vertical grid lines - https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#VerticalGridLinesAtEvery
[2021-06-06 12:24:31] |
Yes, that would be the better option, I completely forgot about that.
[2021-06-07 01:59:30] |
Refer to the Vertical Grid documentation here: Chart Menu: Vertical Grid (Chart menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
