Date/Time: Wed, 08 May 2024 19:41:55 +0000
Data connexion for Eurex
View Count: 351
[2021-06-04 20:17:39] |
User565325 - Posts: 11 |
Hi, i use to trade with CME and the connection is ok I added the Eurex data for this month. How i connect my sierra to access to Eurex data. It seems via CQG for CME right now. But it seems i need another access. Best rergards K |
[2021-06-05 07:40:18] |
You need to update Sierra Chart to the latest version following the instructions here: Software Download: Fast Update And then you open a chart for a EUREX symbol through File >>Find Symbol >> Futures-EUREX. Sierra Chart can be connected to CQG and you will still have access to the EUREX data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
