Date/Time: Fri, 03 May 2024 07:20:09 +0000
simulation
View Count: 584
[2021-06-04 16:42:30] |
aurel88 - Posts: 8 |
Bonjour, je voulais vous parler d'une chose rien de grave, quand je me met en simulation et que je met des ordre d'achat ou de vente et des take profit etc.... ca fonctionne pas, je comprend pas , est ce normal ? Sinon j'adore votre logiciel qui est vraiment top Merci a vous |
[2021-06-04 17:06:02] |
We need to understand the issue better. Put a buy limit order in below the market and then post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#PostingAnImage Instructions to enter an order from the chart: Chart Trading and the Chart DOM: Entering Orders From the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-06-04 17:06:18
[2021-06-07 13:41:23] |
Bonjour voici une capture d'ecran
Capture d’écran (6).png / V - Attached On 2021-06-07 13:40:48 UTC - Size: 174.82 KB - 175 views |
[2022-01-24 05:03:40] |
Do you still need any further help here. This post have gotten overlooked from the past.
