Date/Time: Sun, 22 Nov 2026 22:51:01 +0000
IKBR Data feed with Numbers Bars/Volume Profile with Stocks
View Count: 1118
| [2021-06-03 20:40:36] |
| Jatt - Posts: 4 |
Whenever I try to change the STUDY "VbP" setting of "Display Volume in Bars" to "Bid Volume - Ask Volume" it does not show any previous candle data. They are all 0, except for the bars which form after the chart has already been open and study has been added. It will not show anything for prior bars that occurred before the chart was open. This is on an intraday chart. This occurs for both Numbers Bars and Volume Profile. Is this an issue with IKBR Data Feed? Or a glitch? It works fine for ES/MES using IKBR Data Feed. Please advise. Thanks. http://www.sierrachart.com/image.php?Image=1622752735379.png Date Time Of Last Edit: 2021-06-03 20:44:43
| [2021-06-04 04:55:40] |
For the proper data for Numbers Bars or Volume Profiles for US equities, you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2021-06-04 05:01:44] |
| Jatt - Posts: 4 |
Thanks for that, the same problem also arises when using IKBR data for Futures (ES/MES). Is this normal aswell? Thanks |
| [2021-06-04 05:10:01] |
Yes. In this case you need to use the Denali Exchange Data Feed for CME Group data: Denali Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
