Date/Time: Sat, 04 May 2024 03:54:36 +0000
RTH Sessions + Settlement closing prices
View Count: 532
[2021-06-03 07:55:43] |
User438847 - Posts: 1 |
Hello. Im trying to set up a daily chart for ES futures that shows RTH session only and shows settlement prices as the closing prices. How do I accomplish this? It's not through the historical because I can't change the session times.
[2021-06-03 08:40:26] |
This is definitely not possible, at least we cannot think of how this can be done.
[2021-08-11 06:22:58] |
User499894 - Posts: 42 |
Hello I would like the study "Daily OHLC" to show the settlement price as well - is it possible? |
[2021-08-11 13:57:44] |
If you set it to reference a Historical Daily chart (Use This Intraday Chart set to No) then this is possible. Refer to: Daily OHLC: Referencing Separate Historical Daily Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2021-08-11 13:58:04
