Date/Time: Sat, 04 May 2024 12:37:49 +0000
Demand Index flip upside down
View Count: 498
[2021-06-01 22:38:32] |
User761716 - Posts: 6 |
Hello SC, I started to use the DI indicator today and noticed a weird behavior . See my picture. I had to duplicate the right chart so you can see it. It happens when I scroll the time bar. Bests http://www.sierrachart.com/image.php?Image=1622587032693.png Date Time Of Last Edit: 2021-06-01 22:54:08
[2021-06-02 13:55:27] |
John - SC Support - Posts: 31362 |
We see that the scale is also not being displayed when the Demand Index is flipped. We are not able to quickly reproduce this, so we do not know why it has happened. Can you please get us that chartbook so we can see if we can reproduce it with your chart. Follow these instructions to get us the Chartbook: Support Board Posting Information: Providing Chartbook with Only a Single Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-06-02 20:20:13] |
Attached the chartbook.
[2021-06-02 21:44:00] |
We found the issue and have resolved it. You will see the change in the next Pre-Release update (v 2269). When available, you can update using the Fast Update instructions: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
