Date/Time: Thu, 02 May 2024 18:24:30 +0000
[Programming Help] - Unable to setup Visual Studio
View Count: 1124
[2021-06-01 13:25:46] |
sushant - Posts: 32 |
I am Unable to setup Visual Studio to Debug my study the instructions that I followed are from this link Step-By-Step ACSIL Debugging I was Unable to use Build >> Build With Visual C++ - Debug as I was getting the error can be seen in the screenshot attached. As can be seen no variables are visible in visual studio I have downloaded all the modules available in C++ in visual Studio |
Screenshot 2021-06-01 185227.png / V - Attached On 2021-06-01 13:22:51 UTC - Size: 211.51 KB - 248 views Screenshot 2021-06-01 185422.png / V - Attached On 2021-06-01 13:24:37 UTC - Size: 17.12 KB - 197 views |
[2021-06-01 14:56:17] |
bradh - Posts: 854 |
Did you run "Install Visual C++ Compiler" before or after installing Visual Studio? If you did it after you need to uninstall Visual Studio, then Install Visual C++ compiler, then reinstall Visual Studio.
[2021-06-02 13:41:46] |
"Install Visual C++ Compiler" downloads microsoft visual c++ build tool but when I click download from internet nothing happens
Screenshot 2021-06-02 191044.png / V - Attached On 2021-06-02 13:41:42 UTC - Size: 21.23 KB - 180 views |
[2021-06-02 15:42:40] |
You didn't answer the question. Did you run "Install Visual C++ Compiler" before or after installing Visual Studio? If you did it after you need to uninstall Visual Studio, then Install Visual C++ compiler, then reinstall Visual Studio.
[2021-06-03 16:54:29] |
I don't remember if I ran it before installing visual studio or not so I uninstalled the visual studio and again ran the Visual C++ compiler but still it doesn't installs
Screenshot 2021-06-03 222243.png / V - Attached On 2021-06-03 16:54:19 UTC - Size: 109.42 KB - 189 views |
[2021-06-03 17:21:53] |
Have you tried updating to the current version of Sierra Chart?
[2021-06-04 11:10:31] |
Yes my sierra chart version is 2269
[2021-06-04 11:24:59] |
All of this has been discussed in this thread: Update documentation to support latest version of Visual Studio | Post: 180504 There is one more step I left out. You need to uninstall the existing Visual C++ redistributable: vc_redist.x64.exe /uninstall
Then Install Visual C++ Compiler, and then Visual Studio. Date Time Of Last Edit: 2021-06-04 11:25:59
[2021-06-05 17:14:24] |
where to run vc_redist.x64.exe /uninstall this I ran it in CMD but it didn't run. I manually deleted the redistribute packages from "add or remove a program" in windows 10. Even After that same issue.
Date Time Of Last Edit: 2021-06-05 17:28:06
[2021-06-05 20:02:57] |
cd to the folder where vc_redist.x64.exe lives and run it from there at a CMD prompt.
[2021-06-06 10:02:19] |
I think vc_redist.x64.exe is not present as I am unable to find it. I looked on https://docs.microsoft.com/en-us/answers/questions/220765/location-of-34microsoft-visual-c-redistributable-2.html where I can find it and it was not present. Maybe it is because I deleted it from the "Add or remove program" |
[2021-06-06 19:49:30] |
It this point, I would suggest you do a Refresh of Windows (without removing your files) and start with nothing installed. https://support.microsoft.com/en-us/windows/how-to-refresh-reset-or-restore-your-pc-51391d9a-eb0a-84a7-69e4-c2c1fbceb8dd The process does work. I haven't done it in a while, but I would assume it is system related in your case. |
